J Lucas Posted February 13, 2008 Share Posted February 13, 2008 (edited) Is there a way to set a keyboard key to equal selecting an "OK" buton on screen to complete entering a callout? This would save a lot of mouse actions and time. Edited February 13, 2008 by J Lucas Quote Link to comment
J Lucas Posted February 13, 2008 Author Share Posted February 13, 2008 mar: Enter does not work when closing the callout dialog box after entering text. Enter creates a new line of text. Quote Link to comment
jan15 Posted February 14, 2008 Share Posted February 14, 2008 I don't use callouts, but does the Enter key on the numeric keypad exit instead of creating a new line? It works that way with text objects. You can make a key or key combination perform a mouse click operation using a macro utility such as Macro Express. Quote Link to comment
mar schrammeyer Posted February 14, 2008 Share Posted February 14, 2008 (edited) for me it does, a new line is return could be a mac thing? Edited February 14, 2008 by mar schrammeyer Quote Link to comment
CS1 Posted February 14, 2008 Share Posted February 14, 2008 I find with most pop-up boxes hitting the "enter" key engages the "no" or "cancel" option not the "yes" or "ok" option. It would goof if there was a shortcut key for "delete" also. The "cut" short cut is good for deleting Quote Link to comment
J Lucas Posted February 14, 2008 Author Share Posted February 14, 2008 jan: If you don't use callouts what do you use for leader lines and notes? The problem with the OK button on the callout dialog is that you have to move the curser over it and then click the mouse. So just substituting a key for a mouse operation will not work. Quote Link to comment
brudgers Posted February 14, 2008 Share Posted February 14, 2008 Program any shortcut you want http://catalog.belkin.com/IWCatProductPage.process?Product_Id=157024 25 bucks at Bestbuy. Right hand stays on mouse. Left hand switches between keyboard and Nostromo. Had it about a week. It's great. Quote Link to comment
jan15 Posted February 14, 2008 Share Posted February 14, 2008 The Esc key closes some dialog boxes, and it closes a text editing box, keeping whatever text you typed - same as the numeric keypad Enter key. And the Del key deletes whatever's selected. Quote Link to comment
monkey Posted February 14, 2008 Share Posted February 14, 2008 to finish a callout, you have to use the enter button by the keypad, the normal enter button only pulls down a new line. Quote Link to comment
J Lucas Posted February 14, 2008 Author Share Posted February 14, 2008 monkey, That is the answer I was looking for. Thank you, thank you. That will save a lot of mouse moves and clicks! The post by jan15 had the same answer in it but I did not read it carefully. brudgers, I am going to check out that gadget you posted. Thanks to all, Quote Link to comment
brudgers Posted February 14, 2008 Share Posted February 14, 2008 Once I got it programmed, it paid for itself in about a day. The biggest problem I have is remembering to use it. Quote Link to comment
Ride Posted February 14, 2008 Share Posted February 14, 2008 On a mac keyboard, the usual enter button at the right of the letters is labelled "return", and this is exactly what it does in vectorworks. Definitely must use the enter button at the number pad to effect the closing of dialogue boxes. Quote Link to comment
billtheia Posted February 18, 2008 Share Posted February 18, 2008 Enter key on numeric key pad closes callout dialog box for me. Return key adds a line return. Quote Link to comment
