MTB Posted February 11, 2008 Share Posted February 11, 2008 Have document settings selected for auto associative but do not see any red squares on dimensions and have tried doing it with and without the auto associative set. Do not understand why it is not working. working with a floor plan using standard objects. Quote Link to comment
Don Berinati Posted February 12, 2008 Share Posted February 12, 2008 (edited) I have the same issue. The program seems to associate dimensions randomly but mostly not at all. This seems to be true whether I'm on a design layer or in a VP. I'm wondering if it's happening because the file(s) were converted from VW12.5.x. Edited February 12, 2008 by Don Berinati Quote Link to comment
dcont Posted February 12, 2008 Share Posted February 12, 2008 Make sure you are showing the constraints. Go to View-->Show-->Show Hide Constraints. This turns on/off those little red squares. Quote Link to comment
MTB Posted February 12, 2008 Author Share Posted February 12, 2008 The View-Show-Show Hide selection worked for some instances. However it still does not work when ever I put in a dimension element. I thought when you selected associative it would automatically associate what ever end point you clicked on to that dimension. It does not seem to work that way. Another need is to select a dimension and have a way to turn it into an associative dimension. Don't see how to do that either. Quote Link to comment
