Mark Posted September 13, 2000 Share Posted September 13, 2000 In the Stair dialog there are options for Offset 1, Offset 2 as well as "Separation". Both the Offsets make the landing longer. I can't find anything to make a landing wider without making the stairs wider as well. I can't see what "Separation" does at all. Anyone out there have a clue? Thanks Mark Quote Link to comment
Lyndsey Ferguson Posted September 14, 2000 Share Posted September 14, 2000 quote: Originally posted by Mark: In the Stair dialog there are options for Offset 1, Offset 2 as well as "Separation". Both the Offsets make the landing longer. I can't find anything to make a landing wider without making the stairs wider as well. I can't see what "Separation" does at all. Anyone out there have a clue? Thanks Mark The separation field in the object info palette is used only in double back stair configurations. This value is the space in between each flight of stairs. It will in fact make your landing wider in this case. Lyndsey Quote Link to comment
