Soden333
size of dimension text
I cant seem to edit the size of the text used for dims, i have been into the custom dimension menu but i cant see an option to set the text size. At the moment i am having to change the text manually every time and its beginning to annoy!
Help appreciated.
You can select the default text attributes by setting them with no object selected, the same principle as setting the default line/fill attributes. Unfortunately there's no way to set text attributes by class.
And you can very easily create a Custom Selection script that selects all dimensions in a certain class (or in Dimensions class, to which they're automatically assigned when created), and then use that script to select all the dimensions and assign a text style to all of them at once.
