Mecacarl Posted January 30, 2008 Share Posted January 30, 2008 Is there a way to create a cut-away section in a 3d model (i.e, viewing the exterior house model you'll also be able to see cut-away sections, wall,interior etc for presentation uses) or is this the job of only third party software, and if so which software & methods are required. Or would this subject be best suited for the "Wish List" forum? Quote Link to comment
j.christ Posted January 30, 2008 Share Posted January 30, 2008 Select Model -> Cut 3d Section...if this is not listed you'll need to customize your menu to add it to the list in the Model menu. Quote Link to comment
Mecacarl Posted January 30, 2008 Author Share Posted January 30, 2008 Thanks a million. Real good advise! Quote Link to comment
Pat Stanford Posted January 30, 2008 Share Posted January 30, 2008 If you are using anything above VW Fundamentals, you should also consider using a Section Viewport that will automatically update if the model changes. Pat Quote Link to comment
