johncruet
Editing overhead door dotted line
I'd like to figure out a way I can change the dotted line configuration on the 2D Overhead door plug-in object. The manual gives no clue.
Right now the dotted line is an unacceptable dash. I need to get it to be a smaller dash.
I've never been able to change it either - it looks awful.
Perhaps you could post as a wish-list item.
Have you imported any dwg/dxf files into VW? I did, and had the same problem with overhead doors and the stair tool as well. I had to delete some dash styles in order for the doors and stairs to show correctly. Go to File > Document Settings > Dash Styles.
For some reason the overhead door and stair tool apparantly uses the first dash style in the document, and when you import dwg or dxf files in, those dash styles get messed up.
An option to turn it off would be nice. I've resorted to drawing a white polyline over the top of it.
