johncruet Posted January 30, 2008 Share Posted January 30, 2008 I'd like to figure out a way I can change the dotted line configuration on the 2D Overhead door plug-in object. The manual gives no clue. Right now the dotted line is an unacceptable dash. I need to get it to be a smaller dash. Quote Link to comment
D Wood Posted February 1, 2008 Share Posted February 1, 2008 I've never been able to change it either - it looks awful. Perhaps you could post as a wish-list item. Quote Link to comment
doughd Posted February 1, 2008 Share Posted February 1, 2008 Have you imported any dwg/dxf files into VW? I did, and had the same problem with overhead doors and the stair tool as well. I had to delete some dash styles in order for the doors and stairs to show correctly. Go to File > Document Settings > Dash Styles. For some reason the overhead door and stair tool apparantly uses the first dash style in the document, and when you import dwg or dxf files in, those dash styles get messed up. Quote Link to comment
D Wood Posted February 2, 2008 Share Posted February 2, 2008 Well spotted - I'll try amending dash styles and their order. Quote Link to comment
Don Berinati Posted February 2, 2008 Share Posted February 2, 2008 I'd like to be able to eliminate it entirely. Quote Link to comment
SteveK Posted February 4, 2008 Share Posted February 4, 2008 An option to turn it off would be nice. I've resorted to drawing a white polyline over the top of it. Quote Link to comment
