Why doesn't RecalculateWS procedure work?
David L
Why doesn't the RecalculateWS procedure work? The following simple script should go through a drawing and recalculate all Worksheets but nothing happens. I added the SetSelect procedure to see that something was happening and it does select all worksheets. I tried adding ResetObject procedure per another thread and a couple of other things but nothing makes the recalculate happen.
I would appreciate any suggestions.
PROCEDURE RecalcAllWorksheets;
PROCEDURE RecalcWS(h:HANDLE);
BEGIN
RecalculateWS(h);
SetSelect(h);
END;
BEGIN
ForEachObject(RecalcWS, (T=WORKSHEET));
END;
RUN(RecalcAllWorksheets);
David,
This was discussed back on the Vectorscript list in 2001. weren't you listening ;-)
Apparently ForEachObject works on the list of visible objects in the drawing. If each Worksheet was visible on the drawing your code should work.
Julian Carr (with some help from Robert Anderson and Victor Long of NNA) came up with the following that should recalc all worksheets in the drawing.
Pat
Procedure RecalcWS;
VAR
i : INTEGER;
ObjectName : STRING;
h1 : HANDLE;
BEGIN
FOR i := 1 TO NameNum DO BEGIN
ObjectName := NameList(i);
IF ObjectName <> '' THEN BEGIN
h1 := GetObject(ObjectName);
IF GetType(h1) = 18 THEN RecalculateWS(h1);
END;
END;
END;
Run(RecalcWS);
Pat,
Thanks, that script does the job. I added a count statement after the RecalculateWS statement and a dialog that comfirms the recalc and reports the number of worksheets recalculated, but it reports 434 while there are only 7 in the drawing. With the count incrementor in the GetType IF statement, it should only count the worksheets. I don't know what it is counting. Guess I'll use a dialog that confirms but doesn't count.
BTW: With my original script all worksheets where visible on drawing, but it still didn't recalculate.
Love the PodCad Podcast - never miss an episode.
Hi David,
RecalculateWS operates on the worksheet object itself not the worksheet image on the drawing. You need to get the worksheet object handle from its image. You do this by calling GetWSFromImage
Your script should work if you modify your procedure like this:
VAR
h2 : HANDLE;
BEGIN
wsH := GetWSFromImage(h);
RecalculateWS(h2);
SetSelect(h);
END;
Hugues
NNA
Hugues,
That works like a charm in my original script, using the ForEachObject procedure.
Please try and get NNA to add info like that in the VectorScript Function Reference. It would have helped me if that info was listed in the description of the RecalcWS procedure.
I will post some of these scripts in the Resource Sharing section. All of my VectorScript knowledge came from analyzing other peoples scripts, so I think it would help others to have more scripts available to learn from, especially for people like me with no programming background.
