go2greece Posted January 26, 2008 Share Posted January 26, 2008 we have in our drawings referenced viewports, within these viewports are nested viewports. all nested viewport do not update automatically. is this correct or do i miss some thing? peter Quote Link to comment
cbaarch Posted January 26, 2008 Share Posted January 26, 2008 please explain the proces of how hou managed to get nested VPs Quote Link to comment
go2greece Posted January 27, 2008 Author Share Posted January 27, 2008 step1> in drawing A on layer 1 you create a VP1 saved on designlayer 2 step2 in drawing 2 you refence drawing 1 with disgnlayer 2 as a viewportreference . this viewport has a nested viewport. when you update drawing A only layer2 is updated not the implemented VP. peter Quote Link to comment
Vectorworks, Inc Employee Tolu Posted January 28, 2008 Vectorworks, Inc Employee Share Posted January 28, 2008 Updating drawing A will not automatically update the viewports in drawing 2. However, drawing 2, if open, should show the reference to drawing A in Red - indicating that the file is out of date. What you can do is: 1) Set the reference to drawing A in drawing 1 to "Automatically update out of date references during file open". This is available via the reference tab of the Navigation palette or the organization dialog. 2) If the drawing 1 is currently open, you can manually update the reference to drawing A via the Nav palette or Org. dialog. 3) From the reference settings dialog, you can specify how often VW should check for out of date files. When you are notified that there are out of date files, you will have the option to update the out of date references at that point. Let me know if that helps. Tolu Quote Link to comment
go2greece Posted January 28, 2008 Author Share Posted January 28, 2008 thanks for your info, we will check it. the new reference tool in vw 2008 is a big help for us... we have a lot to do with microstation drawings, were referencing is used extensively. meaning a drawing with hundreds of refs. peter Quote Link to comment
