nickdsa Posted January 26, 2008 Share Posted January 26, 2008 It seems that when I set wall components to wrap a window, but then want to hide said components, the portion that wraps won't go away (see attached file). I'm assuming this is a bug. Can anyone verify that for me? Or show me a work-around? Thanks. Quote Link to comment
Pat Stanford Posted January 26, 2008 Share Posted January 26, 2008 How are you hiding the components? It seems to work for me here. I put in a 12 CMU Brick faced wall and put in a window. Wrapped 2 external components. If I set the components to be invisible at less than 1:1 scale they all go away. If I set a Viewport to not show components, they all go away. What are you seeing? Pat Quote Link to comment
nickdsa Posted January 31, 2008 Author Share Posted January 31, 2008 Hi Pat, I'm just using classes to show/hide components. I think my problem is that I want to show the middle (structural) component of the wall but not the interior and exterior finishes. I don't want to show the wall's full thickness by simply turning off all components. Quote Link to comment
Pat Stanford Posted January 31, 2008 Share Posted January 31, 2008 Nick, I just confirmed the behavior. It seems like a bug to me. I would submit it at http://www.nemetschek.net/support/bugsubmit.php if I were you. Pat Quote Link to comment
nickdsa Posted January 31, 2008 Author Share Posted January 31, 2008 Thanks pat Quote Link to comment
