mike m oz Posted June 24, 2008 Share Posted June 24, 2008 CS1, I assume by slab you mean extrude. Extrude procedure: - Draw your 2D shape. - Extrude to the required height (Model menu). The bottom of the extrude will be at zero. - Use Move 3D to move the object to the required height (Z). To edit the extrude double click on it to get back to the original 2D object. Change this as required and then Exit the Group. Quote Link to comment
CS1 Posted June 30, 2008 Share Posted June 30, 2008 the free "slab object" by patrick higgins does exactly what you want. can be classed separately for 2d view + 3d top sides + bottom, height + thickness of the slab + even rotation of the texture for the sides. fine tool! get it at vectordepot http://www.vectordepot.com/Plugins1.shtml Quote Link to comment
