Assigning Classes to Text
CS1
In VW2008 there is no equivalent to the Class Styles for text. The best option is to use the Custom Modification. Set the criteria to Class is Class2 and Kind is Text. Then you can change all of the text blocks at the same time, even instances on other layers.
There is no way to have all the text block instances change automatically like you can do with the other attributes.
Pat
