sogabe 0 Posted August 25, 2000 This problem is spec or not? When I select 'rendering' menu command to the Extrude object that include each different color object, The Extrude object will be single color. Please follow this sequence. 1. Create some rectangles. 2. Apply different color to the each object. 3. Select the objects at a time. 4. From the 'model' menu, select 'Extrude' command.?iCreated object is group.) 5. From the 'view' menu, select 'Rendering' command and 'QuickDraw3D' or 'lightworks raymaker' mode. 6. The 3D object become the same color. If I select 'ungrope' menu command, each object will change normal color. This situation does not occur by other rendering mode, and occur Macintosh only. Thanks Sogabe A&A Quote Share this post Link to post
Janis Kent 0 Posted August 26, 2000 In order for each of the objects to reatain their individual colors/patterns, you would need to Extrude each object individually, not as multi-selection. When several are selected at the same time and then extruded, they become a group and I believe it is the bottom one in the staking order that controls the attributes. ------------------ Janis Kent, AIA author WorksTutorial & WorksManual Quote Share this post Link to post
