Wes Gardner
Window/Door line weights
This seems to work for me...
The Attributes Palette for doors and windows should be set up thus:
? Fill Style-by Class,
? Fill Color-by Class,
? Pen Style-SOLID (NOT by Class),
? Pen Color-by Class
? Thickness (Line Weight)-NOT by Class
? These settings will allow the line weight set up in ?Use Part Line Styles? dialog to show correctly in sheet layers ? don?t forget to bump up ?Wall Lines? line weight for RCP (Controlled by Ceiling-Main Class)
In addition, when I class the Window ID tag in the Window-Spec class, I can then set that class to a different color as a visual clue that I've "gotten them all". However, this doesn't seem to be true for the Door ID/ Door-Spec class - I can't get a color shift???
