Jim_Allen Posted January 14, 2008 Share Posted January 14, 2008 In 12 you needed to have floor to do rendering. I got the floor from the AEC pallette, but now that is grayed out when I am in the SL workspace. Do I still need a floor to render? If so how does I get one? Jim Quote Link to comment
Jim_Allen Posted January 23, 2008 Author Share Posted January 23, 2008 No one has an answer?? Kevin?? Jim Quote Link to comment
Hunter B Posted February 7, 2008 Share Posted February 7, 2008 Lay down a 3d Poly rectangle and give it a texture. Quote Link to comment
MrTemplate Posted April 15, 2008 Share Posted April 15, 2008 hi folks; i just tripped over this old post. i ran into the same wall, or rather, floor, a couple of months ago. here's what kevin told me: "Draw your rectangle and leave it selected. then from the AEC menu select "Floor..." Give it a thickness and a bottom Z." i don't know if you need a floor for the render to work or not. but after reading your posts and then kevin's note, i realized that you're close. you have to first create the object (rectangle, poly, circle), select it, **then** invoke the floor command. without anything selected, the command will properly be greyed out. hth, shelley Quote Link to comment
Jim_Allen Posted April 15, 2008 Author Share Posted April 15, 2008 Thanks Steve, I knew I was forgeting something - old age!! :-( So how is the summer shaping up? Jim Quote Link to comment
MrTemplate Posted April 17, 2008 Share Posted April 17, 2008 Hi Jim; no spoleto for me. i just signed the contract to write the 2nd edition. upon hearing the news, the staff at the bar downstairs broke into applause..... shelley Quote Link to comment
