AutoCAD 2008
mpkeane
I am working on a Mac PowerBook, using OS 10.4.11, with VW Designer (Educational Version) 12.5.1. I am having trouble importing files sent by a colleague who is using AutoCAD Inventor 2008.
1) Trying to import a DWG file, I get the following error message: "Opening DWG Library Error 8: This DWG version is not supported"
2) Importing the same file saved as DXF I can import it but all the sheets are blank
3) A model made of the same drawing and saved as a DWF is not recognized at all by VectorWorks.
Is this a known problem? Is there a fix?
Thank you.
Marc
6 answers to this question
And DWF is a viewing-only format ? Autocad can't open it either. There's a viewer for it, a free download from Autodesk.
But it sounds like the DXF file they sent you is an older version, so you shouldn't be having problems with it. If using the viewer doesn't sort it out, tell us more about what you get when you import the DXF file, or post the file.
Sorry about that. I forgot. It's hard to believe, and hence to remember, that they don't make a Mac version of the viewer. I guess with their shoestring budget they can't afford any frills.
What about MacDwiff? at http://www.macdwf.com/
And I remember reading that CadViewer is supposed to read DWF's on a Mac, and generally on any kind of machine that has Java installed. Not true? http://www.cadviewer.com
Can you post the DXF file so we can open it and see what's going on?
Though not a free workaround....
If conversions and version compatiblility were issues, one workaround could involve installing asa Windows Virtual Machine (VM ware or Parallels) and running Autodesk's DWGTureView. This gives you a "true" DWG Viewer and Plotting *AND* included DWg Convert to save back to AutoCAD 2004 format.
