Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
IanH
Status of SP2
What is the status of the issues that were initially reported with SP2 - in particular the printer issues ?
I went to load SP2 yesterday and the readme stated the following issues:
The new GDI+ preference may cause printing issues with some PostScript or other printers. If you experience printing problems with GDI+, you should turn off this option when printing. Be aware that this will cause objects with transparency applied to print without transparency.
Additional functionality in VectorWorks 2008 depends on specific features of your video card. For the latest information on our recommendations for VectorWorks 2008, go to http://kbase.nemetschek.net/ and search for "opengl".
The new plan rotation feature in VectorWorks 2008 is not intended to work with sheet layers. It is available only when you are editing in the design layer environment.
Plan rotation has some unwanted interactions with design layer viewports. We are working to resolve these. They should go away when you rotate the plan back to the unrotated plan view.
The exterior wall dimensioner does not work when editing viewport annotations.
VectorWorks may have problems when running on a 64 bit version of Windows with 4GB or more of physical RAM installed. Reducing your RAM to 2GB or using a 32 bit version of Windows will work around the problem.
One of the reasons for me to upgrade to 2008 was the transparency so the workaround for turning off GDI+ is not an option as I am actively using transparency. However, Im particularly after the plant library updates, so SP2 is of interest to me.
I just want to be able to make an informed decision on whether to update to SP2 in particular whether I will loose to ability to print and with transparency after updating to SP2.
BUMP
I'm particularly looking to see if a solution to the 'non printing issues' when using GDI+ has been implemented yet.
Is this the same as the first issue in the readme above and how wide spread is it?
yes, this and other issues with SP2 have me doubting whether my updating was a mistake or not. i would like to go back to SP1......could I receive instructions on the proper technique to reinstall? thank you
timpower: if you would like to revert to SP1, reinstall from your original media, without checking for updates. Then download the SP1 updater, and use that to update to SP1.
I have had confirmation from NNA that the unable to print problem was a problem with the original SP2 Build (82099) and fixed in the new SP2 package, build 82613.
[edit]SP2 installed and printing with transparency seems Ok[/edit]
Edited by IanH
