Bostonluke
Plant Tags
Either use Custom Selection to select all the plants (ie Tools/Custom Selection -> Select Only where Type is Plant) then turn off the tags from the OIP or (with a bit of set-up effort) use a separate class for plant tags and then turn it off
OIP?
Object Information Palette!
I assumed VW 2008 in my reply - IIRC you could use 'Plug in Object' in the custom selection to do the same (or similar) in earlier versions.
Ver 2008 - Go to Navigation box, Classes, turn off the class: Plant-Components -Tags
