Custom Selection does not seem to select anymore.
Custom Selection will only select objects based on class and layer visibility, layer scale, and view.
If your active layer is not set to the same scale and Top/Plan view as the other layers, you won't be able to select objects on other layers. In addition, if your class and layer options do not allow you to select objects in other classes/layers, Custom Selection won't let you do it either.
Without custom selection, can you select one of the objects you are trying to select?
Is your active layer set to the same layer scale as the layer with the desired objects?
Are both (all) layers set to a top/plan view?
