rocitop Posted January 1, 2008 Share Posted January 1, 2008 I have had some free time lately and I have started reading up on vectorscripts and have come across a project where it might be useful to make one. What the script needs to do is select a group of spotlight instruments (this much I have) and then change the 'Draw Beam' field from check to unchecked or vise versa. I think that because the Draw Beam field is yes or no it will require a SetObjectVariableBoolean command. but I don't have a grasp on the handle parameter, the definition is given as SetObjectVariableBoolean(h :HANDLE; index :INTEGER; status :BOOLEAN); but in the example it is SetObjectVariableBoolean(17,FALSE); Where did the handle go? Any tips or pointers? Quote Link to comment
Pat Stanford Posted January 2, 2008 Share Posted January 2, 2008 rocitop, Close, but no cigar;-) It is not an ObjectVariable. The light is a Plug-In Object (PIO). That means that there are a number of parameters (variables) that can be set through the Object Info Palette (OIP). The parameters are stored in a Record. In order to change the parameters, you neet to use SetRField to set them (or GetRField to read them). For a light object, you need to use SetRField(OH,'Lighting Device','Draw Beam', 'T'); OH is a handle to the object. 'Lighting Device' is the name of the record (usually the same as the name of the PIO, but not if it has been localized). 'Draw Beam' is the name of the field (again watch out for localization.) Finally, SetRField always take a string as the final parameter. Since Draw Beam is a boolean, you must use 'T' to turn it on or 'F' to turn it off. To check for the record and field names to use, lookup the parameters of the object in the VectorScript Plug-In Editor. Check out the VectorScript Guide on Plug-Ins and Fields and Records for more information. Pat Quote Link to comment
rocitop Posted January 3, 2008 Author Share Posted January 3, 2008 Thanks that did the trick, now I have another question. How do I get redrawall; to work? The script turns the beam off but the change is not apparent until the lighting fixture is moved or refreshed. Thanks Quote Link to comment
ccroft Posted January 3, 2008 Share Posted January 3, 2008 You might try ResetObject(h). Quote Link to comment
rocitop Posted January 3, 2008 Author Share Posted January 3, 2008 That fixed it, and works much cleaner then the move 2 then -2 command I was using. Quote Link to comment
