ASL Posted December 19, 2007 Share Posted December 19, 2007 When using the Grid Bubble Tool (from the Tool Set Menu > Dims / Notes), I like the idea of the Starting Marker, however, can one also add grid lines such as 1.4 into the line of column line makers? Or should I be adding this to the wish list? What have I successfully been able to label: A, B, C, D 1, 2, 3, 4 1.1 ,1.2, 1.3, 1.4 What have I not been able to do when labeling column lines: A, B, B.3, B.7, C 1, 2, 3, 4, 4.4, 5, 5.3 Also, interesting to note, that when one for instance sets the starting marker as A.2 then all the column lines are labeled with A.2 So how are people labeling the non-major grid lines? Quote Link to comment
