cdavis Posted December 17, 2007 Share Posted December 17, 2007 The entire drawing will export except the worksheet part. Also, in the preview (on the Export Image File screen)with the Render or Wireframe button pressed the worksheet is not visible. The same drawing will export correctly using the PDF export. The file size exported on pdf is over 150 megs for a 22" X 34" drawing. Is this large of file size this typical? Quote Link to comment
Guest Posted December 17, 2007 Share Posted December 17, 2007 I can't duplicate this. What settings are you specifying in the export dialog? Quote Link to comment
islandmon Posted December 17, 2007 Share Posted December 17, 2007 The file size exported on pdf is over 150 megs for a 22" X 34" drawing Are you using Viewports ? What is the DPI of the Viewport ? Try resetting it to 300dpi. Quote Link to comment
cdavis Posted December 17, 2007 Author Share Posted December 17, 2007 It does not matter what settings you use. If you export image from a design layer the worksheet will be visible, but using a viewport makes the worksheet disappear. This happens in all my drawings with worksheets. This function used to work several weeks ago. I reinstalled SP1 with no difference. It does not matter what the DPI is. I tried 72 and 300 dpi without any changes. Quote Link to comment
Guest Posted December 18, 2007 Share Posted December 18, 2007 I still can't duplicate this issue, using the standard settings with 150 dpi. Do you mind sending the file over? Quote Link to comment
