Grey Class does not work
CS1
I have created a basic model with the following layers
Mod Site
Mod Ground
Mod Roof
I can easily view in 3D and say change the visiblity of the "Mod Ground" to grey, the layer now appears to be transparent and grey.
If I try to change say the class "Roof" or "Site model" or any class to show as grey it has no effect. Am I doing somthing wrong?
Yeah no joy, If i change the visiblity of a class to visible or invisible i notice a change but if select gray then no change. Tried creating a basic model using just cubes with 3 different classes and three layers but cant get the gray classes to work
OK wait. In re-reading your original post I noticed you talked about gray classes AND layers. And I was assuming you were asking about layers only.
It might be helpful if you could explain exactly what you are trying to do...
But if you are trying to be able to see through some objects and have others solid (like see through the roof into the plan), then I think you'll have more joy using layers than classes. Using layers you can achieve the following:
However, using classes the result is somewhat different...
Yeah i know how to gray selected layers so as you say i could see through the roof into the plan but would be handy if I could gray classes also, not sure why I would use it yet, maybe if i had the building visible with all the concept objects like cars plants etc in a concept class then i could show those concept items as grey
