Nik9
line weights, paper scale, general madness
Admitting that I may not entirely have grasped proper use of design/sheet layers and viewports which may be relevant (?)
Attached screen shot "exported" shows a drawing (viewport) I want to send to an engineer working in AC and he says he gets a garbled pile up of (8+) undifferentiated layers. So saving each sheet as an individual dwg., if I re-import that same dwg into a blank file, I see the viewport, but text is miniaturized. If I double click to edit design layer, I get a splodge of hugely bloated line weight much like the attached screenshot "imported2" which is infact what I got back from the engineer after his corrections. "Imported1" shows layers scattered and scale off the paper.
Each time I get a drawing back from another office, it's variations on the same theme. But one of the usual suspect are arrows heads detached from their lines/callouts blown up to relative monster proportions. Scarey stuff.
(I'm afraid to take on a new large project based in AC, daunted by these issues of going back and forth with other offices and disgruntled PC People. Doesn't help this fool's credibility)
I'm working in VW12 (till I get untamed Leopard permission issues resolved so I can update to 12.5)
3 answers to this question
When exporting, forget sheets. Just send each layer as a separate DWG. The engineer is not (should not) be interested in your drawings, only your data, and should be able to XREF your design layers the way she or he needs.
right, thank you, I got that much, but the resulting dwg's were still not correct as outlined.
Also, without sheet layers, one can only export VP elevations by ADDING design layer viewports to workflow and one can't export sections at all.
