bonus Posted December 14, 2007 Share Posted December 14, 2007 Are there any known problems with importing IFC files? Before trying different settings etc I would like to know I don't waste my time on this.... Quote Link to comment
Petri Posted December 14, 2007 Share Posted December 14, 2007 So far, import has worked OK, but I have not had a real job to import, just some test files from here and there. Exporting, however, is a major headache. As I have just reported, not even NNA's Plug-in objects export correctly and the process is flawed. In many occasions there has not been any real data in the IFC file - I was this morning surprised that I got a wall and a door go through and come back. (One can open an IFC file with a text editor and view the results. I have many times had all the "general" data, but no actual entities.) The default destination (to which the export dialog jumps to every time) the VectorWorks application. No, not the "normal" application folder, but the one we see as the application. (A special type of folder that cannot be accessed.) After you walk the dialog to the wanted destination and save, you have to go and change the filename: regardless of what options I have tried, the export file gets a name like "The Job.ifc.vwx". So, you go to Finder, Get Info, change the name and convince the OS that you really, really want to use "ifc". In import the only relevant setting is, I think, Object or Project. Quote Link to comment
