Plant tag alignment
Marietta
Is there any way to rotate the plant tag so that it aligns with a rotated viewport? I can make the grid and cross hairs to align in the grid box, but the plant tags do not seem to have any attributes to allow you to rotate.
The same goes for the text callout tool.
With a rotated viewport, these look bizarre, plus with a large plan, it is time consuming to have to add the plant tags manually, and there is more room for error in the numbers.
