Christiaan 849 Posted December 10, 2007 I tried to attached zipped file and then a .vsm file but got this message: We encountered a problem. The reason reported was The files you may upload must have the following extension: : .gif,.jpg,.txt,.png,.tif,.qts,.mcd,.vwx, .dwg, .dxf, .vso, .vsm, .vst, .sta, .pdf Please use your back button to return to the previous page. Quote Share this post Link to post
Guest Posted December 10, 2007 .zip is not supported, as you can see from the list. How large is the .vsm file? Make sure the file name is blah.vsm where "blah" is the file name with standard numbers and letters (no special characters) Quote Share this post Link to post
C. Andrew Dunning 186 Posted December 10, 2007 Katie - I had the same issue w. a VSO file. 42KB. Quote Share this post Link to post
Guest Posted December 10, 2007 Is the file just a name, or does it have name.vso ? Quote Share this post Link to post
C. Andrew Dunning 186 Posted December 10, 2007 The file is named "LandruNoteBox.vso". Quote Share this post Link to post
Christiaan 849 Posted December 10, 2007 (edited) File name e.g.: ToggleActivityZones.vsm File size: just over 2 KB Edited December 10, 2007 by Christiaan Quote Share this post Link to post
ccroft 0 Posted December 11, 2007 I also wasn't able to attach .vst file and got that same message, telling me my .vst file wasn't a .vst This is copy/pasted from the file name: ClassTool.vst Just tried again and still no go. Quote Share this post Link to post
