Vectorworks, Inc Employee Robert Anderson Posted December 5, 2007 Vectorworks, Inc Employee Share Posted December 5, 2007 (edited) Select an object in the drawing that has records attached (this can be a PIO or any object) and run this script. Then click on the drawing and you'll have an on-drawing report of all the records attached to the object. (I use this script all the time -- it's probably more practically useful than instructive, but there are things to learn in here, also.) OK, I've got this forum up and rolling with some useful and hopefully instructive stuff. Let's see some other scripters' work.... PROCEDURE RecordReporter; CONST p_str = 'p'; int_type_str = '\INTEGER\'; bool_type_str = '\BOOLEAN\'; text_type_str = '\TEXT\'; popup_type_str = '\TEXT-Popup\'; radio_type_str = '\TEXT-Radio\'; const_type_str = '\TEXT-Static Label\'; ngenl_type_str = '\NUMBER-General\'; ndim_type_str = '\NUMBER-Dimension\'; nxcoor_type_str = '\NUMBER-X coordinate\'; nycoor_type_str = '\NUMBER-Y coordinate\'; ndec_type_str = '\NUMBER-Decimal\'; ndeccomma_type_str = '\NUMBER-Decimal w/ commas\'; nsci_type_str = '\NUMBER-Scientific\'; nfrac_type_str = '\NUMBER-Fraction\'; nang_type_str = '\NUMBER-Angle\'; ndate_type_str = '\NUMBER-Date/Time\'; err_str_noselect = 'ERROR: Nothing selected. Select an object with a record or records attached and run this script again.'; VAR hobj,hrec:HANDLE; str:DYNARRAY[] OF CHAR; x,y:REAL; i,j,k,l:INTEGER; objname:STRING; FUNCTION UScore(in_str:STRING):STRING; VAR strlen,i:INTEGER; outstring:STRING; test:BOOLEAN; BEGIN outstring := ''; strlen := len(in_str); FOR i := 1 TO strlen DO BEGIN test := (copy(in_str,i,1) = ' '); IF test THEN outstring := concat(outstring,'_') ELSE outstring := concat(outstring,copy(in_str,i,1)); END; UScore := outstring; END; BEGIN hobj := fsactlayer; IF hobj <> NIL THEN BEGIN str := ''; FOR j := 1 to numrecords(hobj) DO BEGIN hrec := getrecord(hobj,j); IF (j = numrecords(hobj)) THEN objname := getname(hrec); IF (str<>'') THEN str := concat(str,chr(13)); str := concat(str,num2str(0,j),'.'); str := concat(str,getname(hrec)); FOR i:= 1 TO NumFields(hrec) DO BEGIN str := concat(str,chr(13)); str := concat(str,' '); str := concat(str,num2str(0,j),'.',num2str(0,i),'?'); str := concat(str,GetFldName(hrec,i)); IF ((gettype(hobj)=86)&(j = numrecords(hobj))) {PIO format record} THEN CASE getfldtype(hrec,i) OF 1: str := concat(str,int_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 2: str := concat(str,bool_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 3: str := concat(str,ngenl_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 4: str := concat(str,text_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 7: str := concat(str,ndim_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 8: BEGIN str := concat(str,popup_type_str); k := numCustomObjectChoices(objname, concat(p_str,UScore(GetFldName(hrec,i)))); FOR l := 1 TO k DO str := concat(str,getCustomObjectChoice(objname,concat(p_str,UScore(GetFldName(hrec,i))),l),','); END; 9: str := concat(str,radio_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 10: str := concat(str,nxcoor_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 11: str := concat(str,nycoor_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 14: str := concat(str,const_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); END {of CASE} ELSE CASE getfldtype(hrec,i) OF 1: str := concat(str,int_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 2: str := concat(str,bool_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 3: str := concat(str,ngenl_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 4: str := concat(str,text_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 5: str := concat(str,ndec_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 6: str := concat(str,ndeccomma_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 7: str := concat(str,nsci_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 8: str := concat(str,nfrac_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 9: str := concat(str,ndim_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 10: str := concat(str,nang_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); 11: str := concat(str,ndate_type_str,getrfield(hobj,getname(hrec),GetFldName(hrec,i))); END; {of CASE} END; END; getpt(x,y); textorigin(x,y); CreateText(str); SetTextJust(lnewobj,1); END ELSE alrtdialog(err_str_noselect); END; RUN(RecordReporter); Edited December 9, 2007 by Robert Anderson Quote Link to comment
ccroft Posted December 9, 2007 Share Posted December 9, 2007 Thanks for this one Robert. A tour-de-force of concatenation and case! One note: It seems that the script has been pasted twice into this code window. I copied it all and pasted to a document script but it wouldn't run. Took a minute or two to see what was wrong. No likey run in middle. Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted December 9, 2007 Author Vectorworks, Inc Employee Share Posted December 9, 2007 ccroft, thanks. The script was indeed pasted twice in the code window. I've fixed it. Quote Link to comment
