Robert Anderson 128 Posted December 4, 2007 (edited) This VectorScript is a prototype that addresses the following topics: -reading information obtained from record data -formatting and outputting that data into a text file The text output can then be used in any number of applications or databases. With minor revisions, this script could be modified to export issue data from the drawing border objects, etc. PROCEDURE export_revisions; CONST errmsg_no_DBs = 'ERROR: There are no Drawing Borders in the drawing to report on.'; putfile_prompt = 'Locate the Drawing Border Revision report:'; putfile_default = 'DB_Revisions'; pio_nm = 'Drawing Border - Universal'; tag1 = 'File name'; tag2 = 'Sheet layer'; tag3 = 'Number'; tag4 = 'Description'; tag5 = 'Date'; tag6 = 'Approval'; tag7 = 'Zone'; VAR outputfile,fname :STRING; cnt_cum :INTEGER; PROCEDURE handle_TB(TB_h:HANDLE); CONST rev_enabled = 'insertRevBlock'; fmt_nm = 'Revision Data'; fld_pfx_1 = 'Description-'; fld_pfx_2 = 'Date-'; fld_pfx_3 = 'Approved-'; fld_pfx_4 = 'Zone-'; VAR cnt :INTEGER; desc,dt,apprvd,zone,lyr_nm,result:STRING; test : BOOLEAN; BEGIN result :=getrfield(TB_h,pio_nm,rev_enabled); uprstring(result); IF (result = 'TRUE') THEN BEGIN lyr_nm := getlname(getlayer(TB_h)); FOR cnt := 1 TO 50 DO BEGIN desc := getrfield(TB_h,fmt_nm,concat(fld_pfx_1,num2str(0,cnt))); dt := getrfield(TB_h,fmt_nm,concat(fld_pfx_2,num2str(0,cnt))); apprvd := getrfield(TB_h,fmt_nm,concat(fld_pfx_3,num2str(0,cnt))); zone := getrfield(TB_h,fmt_nm,concat(fld_pfx_4,num2str(0,cnt))); test := NOT((desc = '')&(apprvd = '')&(zone = '')); IF test THEN BEGIN cnt_cum := cnt_cum + 1; writeln(fname,chr(9),lyr_nm,chr(9),num2str(0,cnt_cum),chr(9),desc,chr(9),dt,chr(9),apprvd,chr(9),zone); END; END; END; END; BEGIN cnt_cum := 0; IF Count(R IN [pio_nm]) > 0 THEN BEGIN fname := GetFName; putfile(putfile_prompt,putfile_default,outputfile); writeln(tag1,chr(9),tag2,chr(9),tag3,chr(9),tag4,chr(9),tag5,chr(9),tag6,chr(9),tag7); ForEachObject(handle_TB,R IN [pio_nm]); Close(outputfile); END ELSE alrtdialog(errmsg_no_DBs); END; RUN(export_revisions); Edited December 5, 2007 by Robert Anderson Quote Share this post Link to post
