Super Trooper?
Petri
I don't think there is a way to get the symbol to always point to an object, but in Spotlight, you can set a "Focus Point". The Spotlight lights can then be set to always point to the focus point. Yes, you can have more than one focus point in the scene.
If you take your named object and placed a focus point wiht it and grouped them, then when you move the object and re-render, the light will follow the object.
Pat
In Spotlight, a lighting device can be "aimed" at a point by setting a focus point.
The focus point is defined using the focus point tool - click in the drawing to place, then set the height of the point.
In the lighting device, select the focus point to associate the lighting device with.
No matter the direction the lighting device is pointed, the light source in the lighting device will aim the beam to the focus point.
