Yellowstone Construction
Custom tool attribute?
I've been trying to make use of a Bezier line dashed without fill.
I can't get it to change. I get a solid line filled. Am I missing something on its use. I've selected the tool and the attributes I want and use the custom tool attributes and still no change.
Try changing its class to make sure the class settings aren't overriding your input. I assume you've tried moving it or deleting it to determine if there isn't another copy below - obscuring the fact that you've changed the upper item.
Thank you. I've given up. I'll change each line after I create it. Worked 2 HRS on trying to make it work. Some things are better done by hand. Instead of wasting time.It would be easier to click the tool, make the settings then double click the tool to hold its attributes.
