kelrock Posted November 23, 2007 Share Posted November 23, 2007 I just recently installed Leopard and Vectorworks 2008 on my MacBook Pro with 2 gigs of memory on board. I now am encountering a problem which I didn't have before. In full render mode I get an error message stating there is not enough mermory. Is there a reason why this should take place? Quote Link to comment
Guest Posted November 23, 2007 Share Posted November 23, 2007 First, make sure you have Service Pack 1 installed. If the problem persists after installing SP1, it is likely you are running out of memory. The model may be too complex for the rendering style chosen. The best thing to do is to send a detailed description of the problem and your OS settings, along with the VW file to tech@nemetschek.net and bugsubmit@nemetschek.net Quote Link to comment
