Kimcz Posted November 19, 2007 Share Posted November 19, 2007 I have tried to install SP1 2008 without success. I get to 88% install. It then says installing 1 of 2. The time line goes to about 1/3rd way, then stops. The install tablet then says 89% install. But the whole install procedure has hung. I have tried this several times, with new downloads. Always the same result. Any suggestions? Katie? Does anybody have the same problems? New computer. PC Dual quad, so there should be no problem. XP Quote Link to comment
Guest Posted November 19, 2007 Share Posted November 19, 2007 How long have you waited at this screen? Quote Link to comment
P Retondo Posted November 20, 2007 Share Posted November 20, 2007 I find that it takes a long time to install VW these days because of the automated update feature. The install program is contacting an NNA server and downloading updated files. Quote Link to comment
Guest Posted November 20, 2007 Share Posted November 20, 2007 You can choose not to do this. The truth of it is that VW is becoming a bigger application each version. The library files is the largest contributor to the size of the application. Quote Link to comment
Kimcz Posted November 20, 2007 Author Share Posted November 20, 2007 Thanks for the replies. I have waited over half an hour for anything further to happen. I will try for longer and see what happens then. Quote Link to comment
Guest Posted November 20, 2007 Share Posted November 20, 2007 Patience may be in order here. If you wait more than an hour, I'd say redownload the updater and run it again. Quote Link to comment
