Geoff Briggs
symbol replacement
Hi all,
there used to be an option in the replace symbol dialog box to replace all instances of a symbol. This is no more. What's the best way to do it now. Custom selection won't select symbols in walls, so that's not an option. Thanks.
Geoff Briggs
Seems that there was a function that would "replace all" instances of a symbol. Maybe it's been buried somewhere else.
As a work-around, within the Resources palette, you could edit that particular symbol and replace both the 2D and 3D components (if both exist) with the desired replacement.
Make sense? Don't know if it will help you, but it should work.
Jack Fulmer
