SteveK Posted November 19, 2007 Share Posted November 19, 2007 When I created a ceiling grid in version 12, the grid could be repositioned using the 2d reshape tool. The handle would be near the center of the grid. I may be missing something, but I don't see this in 2008. Is there a different way to adjust the grid in 2008? Thanks Quote Link to comment
Guest Posted November 19, 2007 Share Posted November 19, 2007 When you choose the 2D selection tool, make sure you have a resize cursor - mode 2 or 3 selected. It sounds like the "no resize" mode is set for the 2D selection tool. Mode 2 allows you to resize a single object when a single object is selected. If more than one objects are selected, resizing is disabled. Mode 3 allows you to resize multiple objects when multiple objects are selected. This resize mode change was introduced with VW 2008 not only as a safety, but for expanded control. Quote Link to comment
Jonathan Pickup Posted November 19, 2007 Share Posted November 19, 2007 use the 2D selection tool to select your ceiling grid. Then you should see a blue dot near the centre. As Katie points out, make sure that you look at the mode bar. The 2D selection tool now has a new mode, so make sure you are on an option for reshaping. Quote Link to comment
