milon
opacity problem by printing
"Opacity" creates problem on lines when I'm printing, 300 dpi, anti aliasing and quartz activated, the lines is printed like staircase. (no opacity no problem)
there's is a problem with this tool!
thanks for your help...
milon
10 answers to this question
OS 10.4.11
Printer -> all printer I have:
HP designjet 800
HP designjet 750c
HP laserjet 5100
HP colorjet 4500
thanks
m.
Are you having the problem when printing to all of the printers, or a specific printer?
Do you see the "staircase" when you export to a PDF, or print to PDF (from the print dialog box)?
I am having problems with the vividness of printing. There isn't any way to make the print darker. The print driver is a Gutenberg and there doesn't seem to be any other.
Epson R1800
VW Architect/Renderworks 2008
hello katie,
yes all printing and unfortunately also pdf xp and pdf print.
I tried, I think everything
xport epsf and distiller...
xport pdf and print from acrobat...
I extract the opacity from design sheet to layer sheet...
the fact is, I apply opacity on a gray surface up to a bitmap maybe that's the problem?
m.
Milon,
Can you send me a sample VW file and the PDF file, please?
Milon,
In the VW Preferences, turn on Anti Aliasing below Quartz Imaging.
Set the Viewport to have a DPI higher than 72, such as 150. Now when you create the PDF, the lines should be smooth.
They will print even smoother than they appear on the screen due to screen resolutions.
I too am having problems printing either pdf's or straight to my HP Photosmart. I have set my dpi to 300 and set ant-aliasing to on but much of my drawing goes missing. I was just using a slight opacity 'window' to highlight a detail on a drawing and if I remove this window the drawing will then print correctly. Has this problem now been addressed/solved?
Yes, I have GDI imaging on and have tried it with anti-aliasing on and off and with the dpi of the sheet on 300dpi as well as 72dpi. If I move the opacity object off the page and print there is no problem.
