can't export PDF in 2008 on a MAC
Is this with a custom workspace or one of the default VW workspaces?
Have you tried removing the export option from the workspace and adding it back?
Did you run VW 2008 before installing Leopard?
Have you run Disk Utility?
In the Applications : Utility folder is something called Disk Utility. When you launch this, select your hard drive on the left and then click on Verify Disk Permissions. When done, click on Repair Disk Permissions.
It's not a bad idea to get in the habit of running Disk Utility any time new software or hardware is installed / removed, or updates to the OS are run.
