cdailey 0 Posted June 15, 2000 Hi... Is there a way to map colors to lineweight after a file has been imported? I understand you can modify in Classes, I was wondering if there was a way to get back to the dialog box that shows up when importing DXF files. Any help will be greatly appreciated. Thanks Craig Quote Share this post Link to post
MikeB 1 Posted June 16, 2000 I think you can do a custom selection by color and then change the line weight, I think this might be the only way to do what you want. Good Luck Quote Share this post Link to post
Guest Posted June 16, 2000 Unfortunately there is no way to go back to the Map Colors to line weights dialogue box that comes up when importing. Custom selection would probably be the best way of going about changing the the lines in your drawing or using the class settings. Quote Share this post Link to post
