Dual Monitors?
Anyone out there able to use a new iMac and hook up an additional monitor? I am thinking about getting an iMac (Leopard/VW interface another issue I realize) and hooking up an relatively new Dell 24" monitor next to it?
If yes, was this relatively easy to do?
Thanks,
Daniel
Yes, iMacs work well with second monitors. You will need a mini-DVI -> DVi converter (unless the new Macs have changed), which will cost around $20. I've hooked up my 17" Core Duo iMac to a 42" LCD TV on occasion (at up to 1920x1200). You can either mirror the original display or have a separate one.
The VW 12.5.3 release should hopefully solve the Leopard/VW interface issue.
I highly recommend dual monitors. We just bought 24" iMacs and are using our old 19" LCD's as second monitors. I would like to get a VESA mount for the smaller screen, mount it next to the iMac and orient it in 'landscape' instead of portrait view. I use the smaller screen for all my palettes and the 24" full screen for the drawings.
Yes, I have 2 monitors too - one for VW palettes and iCal drawing schedule, and the other a widescreen dedicated to be just the drawing window - you'd be surprised how much difference a large screen makes when viewing drawings, and helps save on printing (seeing something in print that you didn't see on your monitor is a big time waster).
I think the ideal setup in the far future will be an A1 size 300+ dpi monitor which acts like a drawing tablet. (somehow they need to be a bit more 'passive' and make use of passive light, than they are at the moment to reduce eye strain) - either that or a projector that is high res on the wall and bright enough for use in bright rooms.
