Jodyb17 Posted November 14, 2007 Share Posted November 14, 2007 (edited) How do I avoid this behavior? The first image shows how a WGR looks in the design layer of one of our drawings. When creating a viewport of this information, the text rotates incorrectly. I have adjust flipped text On. When I turn it Off, the text shows correctly. Why does the text show one way in the design layer and another in the viewport? Edited November 14, 2007 by Jodyb17 Quote Link to comment
Guest Posted November 14, 2007 Share Posted November 14, 2007 Some image hosting websites do not permit links outside their network. To post an image, use the Edit button and add an image using the controls at the bottom. Or, when first creating the message, use the reply button in the previous post rather than the quick reply. In the Announcements section of the message board is a review of message board features, including a step-by-step of including images in posts. Quote Link to comment
Jodyb17 Posted November 14, 2007 Author Share Posted November 14, 2007 Okay, got the images attached. Quote Link to comment
Guest Posted November 14, 2007 Share Posted November 14, 2007 Did this info originate in a dwg file or an EPS/ file? Quote Link to comment
Jodyb17 Posted November 15, 2007 Author Share Posted November 15, 2007 No way for me to know for sure. This is probably a copy of a file that predates my employment here, as it follows the State's format for title blocks. Will deleting and re-doing the text work? I added test text (without deleting others) and got the same results. Start over with a blank file? Quote Link to comment
Guest Posted November 15, 2007 Share Posted November 15, 2007 Hmm .. can you send a file with the title block over? Quote Link to comment
