grant_PD
import fails in 2008 but not 12.5
Tried many times to bring in a dwg file. Converted it to an older version as well. Then brought it in to 12.5 and it worked fine. Any one else seen this happen?
6 answers to this question
Are you getting an error message, if so, what is the message?
Are you using SP 1?
Use Import Single dxf/dwg option and see if it works.
Are you using VW 2008 with Service Pack 1?
I recently had the same problem. When I imported in V12 it worked, although not all text imported correctly. When I try to import in VW2008 it fails with: OpenDWG Library Error 309: Internal Error.
Please send the dwg file to both tech@nemetschek.net and bugsubmit@nemetschek.net. Please be sure to include a detailed explaination of the problem, OS specs, VW specs, and any other pertinent information.
