Paul Dolan 0 Posted June 13, 2000 Hi I need to take a block of text and squash it on the x axis. In other words asymmetrically scale it perhaps x = .4 & y=1 Can this be done ? The application for this is some slanted signage in elevation etc. Any help appreciated PAUL -- Please return or direct all mail to oscarch@iol.ie Quote Share this post Link to post
MikeB 1 Posted June 13, 2000 If you are using a true type font you can use the "true type to polyline" command on the text menu. then Possibly convert to lines, group it, then you should be able manipulate it. Although you can no longer edit the text after you do this Good Luck Quote Share this post Link to post
