doughd 0 Posted November 12, 2007 I am getting very frustrated at having to submit so many freakin bugs for VW 2008. To no surprise, I found another. Please someone tell me what is wrong. I imported a wall style from another VW drawing through the resource browser, clicked on the drawing to start the wall, tabbed to the Length, entered the length, clicked again to set the wall horizontally, go to click the next wall vertically, and the 'smart point' next to the cursor says it's 'vertical', but the wall is far from directly vertical. I tried using a different length, a different wall style that was already in the drawing, nothing different has happened. I am starting to wish we had stayed with Acad! Quote Share this post Link to post
Ozzie 19 Posted November 12, 2007 Do you have Constrain Angle on in your Contraints Palette? Quote Share this post Link to post
doughd 0 Posted November 12, 2007 I've tried it both on and off and still having the same problem, and another: I entered the length, and the angle, in left control line mode. Looked fine until I measured the length of the wall, and the measurement is Wrong! What am I missing here?? Quote Share this post Link to post
Andrew Bell@NV 0 Posted November 12, 2007 There is a bug with entering wall distances via the databar and the horizontal/vertical constraints on subsequent segments. This was introduced while making changes to support 3-D editing of walls, and will be fixed in the next bug fix release. I apologize for the inconvenience. Quote Share this post Link to post
Ozzie 19 Posted November 13, 2007 Andrew, You may know then - when will be the next bug fix release and what bugs will be fixed Quote Share this post Link to post
Guest Posted November 13, 2007 Darrell, Per our other discussion, there's no release date for the next update. I've explained this in the other post when you asked IF there will be a SP2. As I said there, I will repeat again, if there's an issue you want to follow up with, either post a detail of the issue, the bug number if you know it, or send an email. We can look into the status of issues and follow up with you. Quote Share this post Link to post
doughd 0 Posted November 13, 2007 My sales rep at NNA said SP2 is coming sometime in December. Quote Share this post Link to post
Guest Posted November 13, 2007 Until there is an official statement, this is speculation. I can tell you definitively we do not have an expected release date. One of the reasons software companies do not set a release date is due to last minute changes and delays in the process. While it does not always happen, release dates are not accurate until official statements are made. Quote Share this post Link to post
mike m oz 360 Posted November 13, 2007 Not to mention the possibility of a new unexpected problem cropping up from an OS maintenance update from either Apple or Microsoft which would have to be dealt with. Do you guys have any hair left? Quote Share this post Link to post
Andrew Bell@NV 0 Posted November 14, 2007 Not to mention the possibility of a new unexpected problem cropping up from an OS maintenance update from either Apple or Microsoft which would have to be dealt with. Do you guys have any hair left? I do, but that's because I pull Dave's out instead of mine. Quote Share this post Link to post
cbaarch 0 Posted November 14, 2007 dougd one glossary term in the software business that you need to learn is "early implementer" it applies to geeks that have to beta test and/or be the first to try/use software right out of the gate as with any software, early versions are always buggy (nature of the business) if you can not deal with the process of reporting bugs, then maybe sit back; relax and wait for later releases. expecting that version x.0.0 of any software to be perfect is nothing but a pipe dream (-: Quote Share this post Link to post
doughd 0 Posted November 16, 2007 cbaarch, it's not the fact that I can't deal with submitting bugs, I just don't have time. I'll leave the bug submitting to the guys who sit around on their butts all day. Just kidding...that's all I do. You're right, we are just beta testers. This is my first at using a brand new version of any software. Thanks for the input! Is there an easy way to check if a certain bug has already been submitted?? Quote Share this post Link to post
