mar schrammeyer
worksheet
In VW12.5 I could resize a worksheet by percentage in OIP, can anyone tell me where I can do this now please?
In VW2008
Edited by mar schrammeyer
Modify Scale appears to work
Hey and how is Tassy - was down there fishing a month or so ago
Tassie is hot at the moment early fire season,I tried scale objects but no can do it sais, symmetrically or asymmetrical so what is your trick
mar
Ha its own Viewport/
Sorry I was in an old drawing and selected a Viewport which of course scaled - are you in a Design Layer or Sheet Layer?
What do you have in the Worksheet if it is just text just make the text bigger.
I just went back to to VW12.5.2 (Mac) and I don't have any option to scale a Worksheet on Drawing. If I try Modify:Scale, I get the same message (different presentation of course), that Object Can't Be Scaled. Doesn't matter if I do symetrically or Asymentrically.
What do you have to do in 12.5 to scale a worksheet?
Pat
If you can scale a worksheet, it's by way of a third party product as this is not a standard behavior in VW.
The other option to scale a worksheet is to convert the worksheet on the drawing to lines, then scale the network of lines and text. Of course, it's no longer a worksheet if you do this.
How do you do that?
Ooh looks like that is not possible anymore.
You used to be able to convert to group, then convert to lines.
Yep. I have that effect.
I know I did this in VW 11. It was the only way I could get the worksheets to export to dwg without having to export the worksheet as a separate text file.
Bummer - Ozcads Worksheet on Drawing will still allow you to Ungroup but without it what is happening in VW 2008 - could it be called a bug?
So, is there a way to export a worksheet to a DWG file. I have a sheet with an embedded worksheet, plus other lines/graphics. When I export the sheet, I get everything EXCEPT the worksheet.
Thanks
Your two easiest options are to:
1. Upgrade to VW2008
2. Go to and buy a copy of Julian Carr's Worksheet on Drawing. It will convert your worksheet to lines and text that will then export properly.
Pat
Pat
Thank you. Both are viable options; however, it would be nice to have the feature from VW in 12.5.3.
