DDDesign Posted November 2, 2007 Share Posted November 2, 2007 I have a texture based on a filtered image. The image is a scan of timber veneer. I have a problem orienting the grain direction. I've tried rotating it in the mapping pane of the OIP but when I render FQR it appears 90 degrees out to what it appears oin the pane. Then when I exit the group edit of the group the component with the texture is in, the direction changes again. I try rotating the direction in the OIP again, then by the time I'm out of the group edit the direction is still the same. The group was part of a symbol. I had a render on the model layer with two instances of the symbol with different directions on each - that surely shouldn't be possible!? Also when I render a viewport the direction is different to the rendering on the model layer. Quote Link to comment
panthony Posted November 2, 2007 Share Posted November 2, 2007 David, I have noticed that the direction of a texture in a single unmodified solid will render in the direction of the map. However if you have a solid that has been subtracted, added or intersected the mapping direction does not orient properly due to the fact that the edited solid is in a group. I have a real problem in solids that have been rotated from the X,Y plane and have been cut such as would be accomplished with a rafter plumb cut or ridge cut. My work-around has been to convert the solid to nurbs and work with the planes independently...takes time though. Pete A. Quote Link to comment
DDDesign Posted November 2, 2007 Author Share Posted November 2, 2007 Pete, the problem in this case is a plain extrusion. Quote Link to comment
panthony Posted November 2, 2007 Share Posted November 2, 2007 David Can't you adjust the grain direction directly from the OIP Render tab > Rotation rather than going all way down to the texture map? Pete A Quote Link to comment
DDDesign Posted November 2, 2007 Author Share Posted November 2, 2007 Yes, I can, but it's exactly the same thing. The change occurs after exiting the group edit. It's like the group somehow overides the object's texture attributes, but this shouldn't normaly happen. (I thought it only happens when you ungroup and check the apply option.) I've done a workaround by ungrouping everything I can, but I still would like to know what's going on. It's happened to me before- I think I had to use another texture last time. Maybe the texture itself has something to do with it - though I can't see how. Prior to using the new texture I had another one working perfectly well as far as direction goes. But when I created the new texture it was the wrong way around and I had to change all the mappings. Which leads me to reiterate a wish that I've seen stated before - that the should be a facility to globally rotate direction during texture creation and editing. I wonder if VW2008 has fixed this. Quote Link to comment
islandmon Posted November 3, 2007 Share Posted November 3, 2007 Often the easiet solution is to create duplicate textures with the various rotations. This helps avoid the unwanted rotation upon substitution problem. Quote Link to comment
grant_PD Posted November 3, 2007 Share Posted November 3, 2007 keep up the discussion though, and post it all to the wishlist forum. The texture mapping in RW needs to be reworked. The manner in which I create an object shouldn't affect how the wrapping paper is applied. Quote Link to comment
