rsa Posted November 1, 2007 Share Posted November 1, 2007 This has always puzzled me... if I have a rectangle that is 1" on a side why won't VW allow me to use (2) 1/2" fillets to round it over. I have to fillet one side with 1/2" and then subtract .001" to fillet the other side. Am I missing something? Quote Link to comment
DDDesign Posted November 1, 2007 Share Posted November 1, 2007 Yes, and heres's what I found is strange -it happens for some corners and not others. And success can depend on which order the fillets are done. Sometimes if you can't do a corner you can fillet another corner - and then come back and fillet the unsuccessful corner later. Two other things - I couldn't find any repeatability in my tests = sometimes it workd in one one, then the next time it didn;t work. Also I tried it with metric units and didn't have any problems at all. Must be a bug. Quote Link to comment
islandmon Posted November 1, 2007 Share Posted November 1, 2007 Obviously, if L=1 and fillet radius R=0.5, then in fact an arc of R=0.5 and sweep of 180? will satisfy the rounding of the edge. The use of two 90? fillets is not recommended in this situation. The fillet is responsive to "fine-ness" of the pre-set 2d resolution > segmentation of the arc. Quote Link to comment
jan15 Posted November 1, 2007 Share Posted November 1, 2007 You could get what you want easily by drawing a 1" dia. circle inscribed in the square, then dragging one edge of the square to the center of the circle and using the Add Surface command. Quote Link to comment
rsa Posted November 1, 2007 Author Share Posted November 1, 2007 Yes I do the circle thing often - it is just that my instinct is to reach for the fillet tool... The fine-ness makes sense - that is what it acts like. Quote Link to comment
Guest Posted November 1, 2007 Share Posted November 1, 2007 Has anyone confirmed that this may have been fixed in 2008? I have experiences this behavior myself in the past, but could not replicate this in 2008. In other words, it seems to work now. As far as the "fine-ness" and resolution dependance, that does not make total sense to me, because the resulting shape is a polyline, not polygon, and therfor is not segmented at all. Righgt? Quote Link to comment
Dave P Posted November 2, 2007 Share Posted November 2, 2007 Just tried it in 2008 and it works fine in all three modes. Quote Link to comment
