dontevenjoke Posted October 31, 2007 Share Posted October 31, 2007 I have used the floor tool to create a floor slab but I can't understand why it's not rendering on the top and bottom faces. All I get with any rendering is the edges. Have I got a setting turn off or what? Many thanks. Quote Link to comment
mike m oz Posted October 31, 2007 Share Posted October 31, 2007 Your 2D shape is probaby incomplete. Double click on the floor object to get to the 2D shape from which it was created: - Look on the Object Info Pallette to see if it is closed. If it isn't put a check mark in the box on the Object Info Palette against "Closed". - Look for edges which are "hidden" (ie. no line). Use the Hide or Show Edges mode of the 2D Reshape tool to show the edge (click on the hidden edge's centre point handle to change its visibility). Quote Link to comment
Vectorworks, Inc Employee Dave Donley Posted October 31, 2007 Vectorworks, Inc Employee Share Posted October 31, 2007 Hello Simon: The floor is probably set to have no fill. Set it to have a solid fill. HTH, Quote Link to comment
dontevenjoke Posted November 1, 2007 Author Share Posted November 1, 2007 You guys are planet savers! Well, My planet anyway... Thanks very much. I was creating the floor first then trying to render it. Again gratitude, Quote Link to comment
