Hidden Line Problems in VW2008 Viewports
laldenj
Thanks for the suggestion, but that makes no difference for me. I'm in WN XP Pro environment on Dell Workstation so, perhaps, that's the problem but have never had these problems on previous versions. I can get Hidden line to render fine but all attempts to select sketching of results are ignored when in viewport.
In case someone else is agonizing over this issue, a bit of clarification:
It appears that the culprit in my model is an imported SketchUp entity. Without the SU component(symbol in VW), the viewport renders perfectly; with it, the entire viewport will only render in simple hidden line---no sketching of the HL is enabled.
I have tried various remedies such as converting to mesh and then to 3D polys to try to sterilize the model of the SU toxicity but have only had success with the most simple of SU imports.
