RonR Posted April 17, 2003 Share Posted April 17, 2003 I need to create a recessed rim, beaded gasket, and mating surface inside a small instrument case. I have tried using the extrude along path command, following a NURBS curve for the path and selecting all three objects to extrude so I maintain a precise relationship between them. Unfortunately I seem to have trouble separating the objects after the extrude- I need to combine each with a different solid, and when I ungroup, they separate into (many) individual NURBS surfaces, not into the shapes defied by the original extrude objects. My questions are: 1) Is it possible to define the precise point on an object that follows the path? I don't see any reference in the manual, but the path appears to track the object center. If I could define a point that that followed the extrude path I could treat the objects separately and still keep a consistent fit after the extrude. 2) Can I extrude multiple objects along one path and separate them after the extrude? Thanks, RonR Quote Link to comment
Hannes Posted April 17, 2003 Share Posted April 17, 2003 hello, You can use the "edit" command to enter the extrude's profilegroup ( or the Path, of course) and move the profile(s) to the correct position. HTH, Hannes Quote Link to comment
