Ozzie Posted October 21, 2007 Share Posted October 21, 2007 In VW 12 in Edit Plant Definition we could change the 2D or for that matter 3D Symbol we used for a particular Plant. Unless I am missing something in VW 2008 it appears we have LOST this ability. Or am I wrong? Quote Link to comment
jonahdicker Posted October 21, 2007 Share Posted October 21, 2007 (edited) This "improved" tool is killing me!!! The five defaults are awful so I have meticulously followed the instructions for adding new ones and it causes VW to crash and/or freeze every time. I have tried the xFrog files that came with the software and the iSymbol files I used in 12.5 and I get the same resault. The new images will appear in the 2d default file but once one is selected the system crashes. Only the initial five images are selectable. I have removed and reinstalled the software only to experience the same problems again. PLEASE HELP! Edited October 21, 2007 by jonahdicker Quote Link to comment
Ozzie Posted October 21, 2007 Author Share Posted October 21, 2007 Have you tried the ones in VW2008/Libraries/Plants/Plant Objects. There are two files - Plant Object Lines and Plant Objects. If you try one from Plant Objects in a new file you will notice 'fill' Classes which you can change. Dunno why you are crashing though. I put both of these files in my Favorites to use as I want to Quote Link to comment
Thom Posted October 22, 2007 Share Posted October 22, 2007 CruisinLong I do not find the plant object lines in that location. Quote Link to comment
Ozzie Posted October 22, 2007 Author Share Posted October 22, 2007 I am from Australia - maybe our version is different Look through the folders in your VW 2008 installation Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted October 23, 2007 Vectorworks, Inc Employee Share Posted October 23, 2007 You should be able to drag any of the xfrog or V12 symbols onto your drawing, then select them and use Landmark / Create New Plant. You can then define your plant as normal. Once created, if you edit the symbol which results in your resource browser, you can choose teh 3D part of the symbol and choose a 3D view from the Xfrog libraries - it should snap to the 3D locus. It's SO MUCH EASIER because you can just draw a symbol on your drawing if you like and then turn it into a plant. Tamsin Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted October 23, 2007 Vectorworks, Inc Employee Share Posted October 23, 2007 i.e. Any symbol can be turned into a plant - it doesn't have to be in the 2D or 3D symbols files like in the old days. Quote Link to comment
